Hi,
Attempting to setup my fenix 5 Plus to last a full Ironman this coming weekend - it's likely going to be a slow one (14+ hours).
I'll be using a HRM-Tri throughout, on the bike a Vector 3 power meter and a speed sensor, then for the run both a Garmin food pod and temp sensors, with everything talking ANT+.
I plan to disable the normally recommend things: turn off bluetooth, wifi, backlight, have the bike and run activity GPS set to "GPS only" without secondary GLONASS or Galileo.
I do however have some questions others might have experience of:
- My watch has lots of other sensors paired (mostly other bikes, foot pods, trainer etc) - will disabling these make any difference? My understanding is no, as it only looks for sensors during the first few minutes of each activity (and tested just now by activating my bike speed sensor after have a dummy cycling activity running for several hours = does not connect).
- The optical HR is set to auto, which by my understanding means it will be off for the swim (always) then off for the rest as it'll pickup my HRM-Tri and favour this - correct?
- Will disabling the Activity Tracking feature make any difference? I would assume yes to prolong battery life in general smartwatch mode, but perhaps negligible when recording an actual GPS-based activity?
- Similarly the watch face - I can't see this making any difference unless it is on the screen, which it won't be during the activity?
- Mapping - I don't plan on using any of the mapping features - will removing the map screens from my bike and run activities make any difference?
- Music - again, will not be using this - is there anything here I need to disable?
I'm currently doing a rundown test - last night I fully charged then did just over an hours open water swim, then a few hours later started a cycling activity left running throughout the night (I've done 5.1km so far apparently!) and during which I've started to prune some of the settings like turning off bluetooth and wifi etc as I remembered - running total is around 11.5 hours with 32% remaining, so extrapolated out that is just under 17 hours. HOWEVER my main concern is this is with NO sensors connected (other than a temp it's picked up from my trainers in the garage!), with little movement throughout the night, and from memory it's when I'm cycling that it takes the biggest hit on the battery (the power meter perhaps?).
All experiences/ideas/thoughts welcomed! I'll also try another rundown test tomorrow during the daytime which might be a little more representative in terms of movement and maybe I'll wear the HRM-Tri, though don't think I'll be able to get in much cycling at this late stage!
(my plan b is to just not record the bike on the fenix - I can use an Edge 1030 for that - though ideally would like it all recorded on the fenix as a multisport activity if possible)
