questions re Fartlek workout
Hello,
Any insight would be appreciated. I have a couple of questions about data screens during a workout.
I did a fartlek workout from a marathon training plan in Garmin Connect. I selected the run on the watch from my training calendar and began the workout. First question, what are the automatic data screens called that come up when you select a training plan workout? In other words, when I do a run in my marathon plan, I select it on the watch and for instance, a long run for 75 min in HR zone 2 starts with a data screen that I did not create for runs, rather a nifty screen that has HR zone 2 in the middle, and time remaining below it, I like it but just want to know what that feature is called? Auto data screens?
At any rate, what I'll call the auto data screen for fartlek workout had three fields, I believe they were time remaining, and step pace and step distance. What are step pace and distance? Step distance seemed to be my distance I had run. I do have my watch set to do auto laps.  Before I got to one mile (auto lap set to 1 mile) I pressed the LAP button to see if that was what the watch was wanting me to do as I changed pace running, big mistake that ended the workout, or rather began the cooldown timer.
Had I left the watch alone, what would have happened with the steps?
Also, after I hit the lap button and screwed up the workout I discarded it. Should I have selected "start over again"? or something like that? Because after I discarded the workout, I began a new run, from my training plan, the fartlek for today, but the nifty auto data screen did not show up for that workout.
Thanks,
M
  • Steps:
    A structured workout is divided into steps. Each step has something you need to do, an intensity you have to do it at, and a duration you have to do it for. This is an example of a workout with 5 steps:
    1. Warm up for 5 minutes.
    2. Run for 10 minutes at a heart rate of 150-160 BPM
    3. Recover for 5 minutes
    4. Run for 10 minutes at a heart rate of 150-160 BPM
    5. Cool down for 10 minutes
    You can see this if you create a custom workout in Garmin Connect.
    Step distance and step pace is your completed distance and average pace so far within the step you are currently doing.
    Screens:
    I have no idea what the screens are called. But they come up in any structured workout, with slightly different content depending on how you selected the duration and intensity of each workout step.
    Lap button:
    When you are in a structured workout, pressing the Lap button will advance you to the next step in the workout. If you do it in the last step in the workout, the workout will end. (In some cases, your training session will continue to record. In other cases it will not.)
  • Thank you Allan for the answer, I appreciate it.
