TL;DR version:
- As of recently (though before the latest v7.6 firmware upgrade) Fenix 5 Plus now takes significantly longer to power on (minutes as opposed to seconds) with the screen displaying “Loading Maps” for most of that time - this has been going on for a number of weeks, have been meaning to investigate.
- When zooming in/out on the map (standard/latest Garmin TopoActive Europe 2019.10 installed) it now takes 30+ seconds to render the map on the screen - only noticed this for the first time last night (don’t regularly use the mapping/routing functionality, most of the time used as a triathlon training watch).
- Similarly, in troubleshooting I noticed when using using the POI database (which also seems slow, though no baseline to compare) and selecting ‘Map’ for a given POI, it takes 30+ seconds to display the map with detail.
- Generally when navigating around the menus/screens it seems a bit more laggy than I remember (though unsure whether this is just a placebo effect).
- Tried re-installing maps via Garmin Express = no improvement.
- Firmware also updated a few days ago to latest stable v7.6 = no improvement.
Q1. Can others confirm that, with the standard/latest Garmin TopoActive Map setup, basic functionality (ie. turning on and using maps) is significantly quicker than this? Ideally someone with the latest and greatest TopoActive Europe 2019.10 (upgrading to which might have been the trigger point to these issues starting)?
Q2. Is a Factory Reset likely to help my (presumably map-related) issues?
Q3. I’m focussing on maps here, for obvious reasons, however could this be misguided and in fact there be something else slowing me down?
Q4. Any obvious troubleshooting steps before jumping to a Factory Reset (which I’ll reluctantly do, including setting everything up again, though will be somewhat disappointment if the problem remains!)?
Thanks in advance.
