so i am very new to the garmin wearables and just picked up the fenix 5x plus. I am wondering if there is a way that the watch will not only track my run but notify me of every km reached and the time of each km.
Yes, you can set whatever value you like.
Short answer: yes.
Long answer: You have two options, which I've detailed below.
If you want to see this alert on your watch, you need to turn on "Auto-Lap" in the settings for the activity you will be using. See here: https://www8.garmin.com/manuals/webhelp/fenix5plus/EN-US/GUID-5E34E41D-D8CB-496E-839D-BC1F0CBFCC48.html
If you also want to hear a message (in your headphones or through the speaker of your phone, if connected to the watch via bluetooth), these are called "Audio Prompts" under the watch's settings. If you go to Settings > Audio Prompts, you'll find an option called "Lap Alert." (See more info here: https://www8.garmin.com/manuals/webhelp/fenix5plus/EN-US/GUID-D7092CFC-0284-4DEE-A89E-8D932F0F0ED3.html).
For both of the above, if you wanted an alert every 1 km, you will also want to ensure you auto-lap distance is set for 1 km. Hope this helps!
amazing !!!! i truly appreciate you taking the time to help.... thanks so much
