Bluetooth Earbuds Reconnection Issue
Does anyone have to reset their F5 in order to get your earbuds to connect via bluetooth? Not just a power off, but a hold down the light key reset. I've tried multiple different buds and the issues persists. Anyone else have this issue or find a workaround? I Love the F5 overall, but that's irritating as can be.
  • I've never experienced this. What earbuds are you using?
    Mostly the Jabra Elite 65t, but I've tried a few others with a similar issue. What kind do you use?
    Have you updated to 7.1? It's much better with the new firmware. Before I have had to re-pair the headset every time I've used it. Now it works fine. Using 65t too.
  • I use the Jabra Elite Active 65t's as well. When I first got them, I battled to connect, but then I found the easiest way was to make it connect to my phone first with the Jabra Sound+ app, then connect from the watch. The buds will say 2 devices connected, then you know you're connected properly.
  • Jabra Elite 65t and version 7.10. I will try that because my last two runs, I have had to Remove it and re-pair it. I actually turned my bluetooth off on the phone thinking it was interfering. I can't get the 65t to reconnect at all without a re-pair. Also - off topic but the Comply earbuds on them worked well today (Better than the ones that come with them).
    My 65t I have my phone BT on, let them connect to my phone first then hold music button on watch and connect. Otherwise they never connect.
  • The phone on and paired solution works. I would never have guessed that.
