1) Turned on my F5+ on to find out that OHR is not working and stuck. Watch face showed " -- " instead of heart rate and the respective widget showed stuck on "measuring". Restarting the watch did not help, several times in a row at that. Only "settings reset" fixed it.
Anyone know an easier way to clear the error and the cauese? Anyone has seen this bug before? Had similar issues with F5 a year ago, no other solution.
2) Another issue is my Jabra Elite Active 65t headphones refuse to reconnect to the watch every time after initial setup. Basically, I have to delete them from the list of headphones, then pair anew every very I go for a run. Reset the settings, did not help. Headphones reset did not help either. Anyone has similar issue and successfully resolved it?
