Fenix 5/5s Plus - 6.58 Beta Release
Hello Fenix 5/5s Plus users,
We have new beta software ready for your upcoming adventures!
Fenix 5S Plus: https://www8.garmin.com/support/down...s.jsp?id=14333
Fenix 5 Plus: https://www8.garmin.com/support/download_details.jsp?id=14331
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
6.58 Change Log Notes:
  • Fixed an intermittent issue where one was not able to connect to Wifi after a powercycle.
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 Plus series you have in the subject line.
  • Is there a reason the Sensor Hub version for the 5X+ went from v230 to v221?
  • We have now since the 30 of November been offered 2 betas but no new Release. Is it the plan that we should use beta software for Fenix 5/5s Plus in the future or when will you move these bug fixes to a proper release.
  • Barometer widget works totally incorrectly. No graph at all. It shows line for a moment and then clears. 3rd party CIQ widget is ok, pressure is ok too.
    SW 6.58, ANT BLE 3.32, Sensor hub 2.30 Wifi 2.50, GPS 2.50
  • For me battery life seems to have become worse;
    3-17-2019 12:53:24 UTC
    Software: 6.58
    Time on since last charge: 4d:23:21:50 (429710 sec)
    Time in low power: 4d:20:33:15 (419595 sec)
    Time with backlight on: 01:10:05 (4205 sec)
    Time with GPS on: 02:07:21 (7641 sec)
    Time with OHR active scan on: 00:42:02 (2522 sec)
    Time with WIFI on: 00:00:40 (40 sec)
    Time with ANT active scan on: 00:24:33 (1473 sec)
    Time with BLE active scan on: 00:26:40 (1600 sec)
    Time with GCM connected: 4d:21:08:31 (421711 sec)
    Device info when plugged in:
    Battery percentage: 27.859373%
    Current backlight mode: 3
    Current backlight brightness: 20%
    I also still have this annoying bug;
    When doing a scheduled running workout, and getting an alert, heart rate for example, the screen sometimes switches to the first default data screen, first in black, instead of going back to the workout data screen.
    Very irritating when doing a heartrate based interval!
    Anyone else see this issue?
  • Bonjour je voudrais savoir avec quel widget ou application vous arrivez à avoir une analyse aussi fine de votre consommation batterie merci à vous
    Marcski79, Fafaesc03 is asking wich widget or app you used to get those precise numbers of your battery consumption ?
    And as a matter of fact, I'm also interested :-)
  • It is from the widget called "Device Usage". This is a built-in widget that I believe is only visible on the watch. So you must add the widget from the watch, not from the Mobile App or Garmin Express. Go to any widget, hold the "up" button, scroll down to and select "Add Widget", and then scroll to the end where you should find "Device Usage".
    Great ! Thx
  • Correct, but the text was actually from the usage file in the DEBUG folder
