2018.20 Australia & NZ Map Update Fail
Two weeks ago I had an issue updating the maps for my new Fenix 5X Plus, contacted support and was told that Garmin Express wasn't compatible with a 4G wifi connection and so they couldn't help me. I have since upgraded my connection and have successfully downloaded the 2018.20 topoActive maps, however on install I am getting the error "There was an error installing the update."
Not only that, but the original maps that were on the device have now been replaced with the most basic map that only shows major roads and no contours. I now understand that a backup of all files on the watch would have been advisable before an update is carried out, something which I would have thought would automatically be done before an update by Garmin Express.
I have contacted support again and they offered me a refund. I told them that I bought the watch because I want to use it, not to get a refund. After 1.5hrs on the phone I have now lost all of my user settings/history after completing the requested factory reset.
I have now sent all files to Garmin Support minus map files in hope that they can sort something out - when is another question. I have never had an issue like this before and I have owned 3 other Garmin devices in the past 10 years. I use the watch for my business reviewing and writing up hiking trail guides in Australia, I need it sorted asap.
Garmin Express is now stuck in the install mode for this map and won't let me download it from scratch, much like the other maps already on the device - I have deleted the other maps files, and they re-download and re-install without an issue when I select Map Options -> Reinstall Map. I need to have this option for the 2018.20 A&NZ Map, or a download link for the file which support say is not possible.
  • Volker_I. That email address goes to the team that always working on Beta Software. Let's let them focus on the beta software and issues that are found with that.
    In your case, since it is the German forums, I would suggest they contact the German Product Support team directly (Information at the bottom). Anyone outside of that, I would suggest looking up your local team too. That way there is no language barriers (or failed transactions issues). If you are not worried about that, feel free to reach out to the US Product Support team.
    Hi Garmin-Heath
    I can't save my setting to turn on private message function in order to reply your message. The solution comes from Garmin support international.
  • Everyone! I am happy to let you know that Express has come out with an update (ver. 6.13.0) and this update was released to fix this issue! Please update your express and then update your maps.
    If you run into any issues, please let the Garmin Support teams know so we can address it right away!
    Thank you for working with us, it has been my honor to work on this project with all you.
    Heath
  • The fix through 6.13 above worked for me, but only after a few attempts at downloading. Once it went to the original error message, another time it froze up & I rebooted but download resumed & finally did complete. You may need to stick at it. Glad it's fixed, but as a tech company Garmin need to (a) better test updated prior to release and (b) get fixed out quicker for what seems to be a minor file copy issue
    As Heath mentioned above, got this email below yesterday. Hope that it works for everyone. I'm happy that there is a fix, but I'm not happy that it came more than 3 months after first appearing. The amount of time I have poured into this, trying to fix an issue that wasn't mine, sending log files, hours on the phone to support, scouring the net for fixes/files, driving hours to get to a store for warranty replacement etc is not something that I would expect from a product that costs over $1000.
    Hello,
    Thank you for your patience as we work through resolving the issue of downloading the latest TopoActive map update to your watch. We have created a fix for this issue. Please update Garmin Express to version 6.13.0 and then attempt the update again.
    If the update does not resolve your issue, please let us know.
    If you need help updating Garmin Express, see the following article - Updating the Garmin Express Application
    If you have additional issues that require troubleshooting, please contact Product Support.
    Thank you for choosing Garmin,
    Brandon
    Product Support
    Garmin International
  • The 6.13 update to Express for Mac worked and the update to the map worked first try. Phew....
    Still does not download using Garmin Express for Windows. Update to 6.13 and attempted update. The speed of the download just drops to nothing and the download does not go anywhere. Tried using broadband internet and via 4G using phone hotspot. Have also uninstalled and reinstalled garmin express and still the same problem.
    Heath
    I have again tried to update the maps this morning using new version of Garmin Express and still getting the error message. Appears that the problem is not fixed!
  • Lukemc29 Thank you for reaching out to us about you continuing having an issue updating your maps. Can you please reach out to the Garmin Support Teams so that we can work with you directly and confirm that there is no other thing causing what you are experiencing?
    Hi All
    Is it safe now to update the maps? especially Topo 2018.20 Au and NZ? Thank you
  • NormanDH Yes. I would be shocked if you run into any issues, but if you do, feel free to reach out to the support teams and they will be happy to walk you through it.
