Hi,
I'm considering getting a Garmin Fenix 5/5X Plus. I have some questions in that regard, which I hope, you might help answer.
Sometimes I listen to podcasts, when running. As I understand it, there is no easy way to subscribe to for instance a podcast feed and have the podcasts transferred over wifi to the watch?
As I understand it, in general you have to connect the watch using a cable to a PC to transfer for instance an MP3-file manually for listening. I am aware, that there is a Spotify app for the watch, where you can listen to your playlists 'offline' if you are a premium Spotify user, which I am. But the podcasts I normally listen to is not on Spotify.
Also I'm aware of an app called Runcasts, that can transfer podcasts to the watch for offline-listening. But as I understand it, you need to subscribe to the app to really be able to use it. And I don't feel like paying a third party for content, that is otherwise free. And apart from that, Runcasts does not seem to carry my podcasts anyway.
So to cut it short: Even though the watch has wifi, I would still need to connect it by cable to a PC to transfer for instance podcasts? And also do I need the cable for other stuff as well, for instance firmware updates?
Apart from the above, I'm an avid Linux user. Which means I don't have a Windows installation or Mac OS for that matter. So even though I was to connect to watch, by cable, to transfer the aforementioned podcast-files, I'm unsure, whether I would be able to transfer anything, since I wouldn't have Garmin Connect, which is not published for Linux, but only for Mac OS and Windows.
Does anyone know, if the watch shows up as external storage for instance, so I would just be able to drag the files I need to a certain folder? Or does it only communicate with Garmin Connect?
Any help would be much appreciated.
