Evening all!
I took the new 5S Plus out this weekend for a hike. I wanted to create a round-trip course on the fly, navigate using it, and try out a pile of data fields to see what worked and what didn't.
Taking things in turn:
1. Course creation: i could have done this in either Garmin Connect (synching the output), or on my watch (but not Garmin Explore, if i'm not mistaken?) - i chose Garmin Connect as i was indoors and it's easier and quicker. But some questions here: despite it being in the Cotswold countryside, and despite picking 'hiking' (as opposed to road cycling or running) it mainly stuck to roads, which was a little disappointing. Is there a way of forcing it to stay on tracks/trails/bridleways, where possible? And once the course is created, i found it difficult to 'drag' the route in order for it to take in certain sights/locations..it really wanted to stick with what it had created for me. Is there a way of asking it it to take in certain locations on the map as part of the course? Almost like creating direction 'via XYZ'. I couldn't find anything that let me do that, so had to take a few manual diversions...i know i can make 'freehand' alterations, but it would be great to have GC do the hard work, taking paths.
So all in all.... is GC the best application for this? or would the watch have been better? (or would it have been identical, using the same algorithmns, etc?) Or would Garmin Explore have been better, of only i knew how to use it...
2. Adding Course/Waypoints: i added a couple of Couse points (=waypoints?) on the course created by GC (the summit, for lunch, and a point at which we rejoined the main road, just to prepare for it), but when on the hike the 'Dist Next' and 'Time to Next' fields seemed to relate to the next turn in the navigation course, rather than the points i manually added. Does the process of course creation effectively create a 'waypoint' for every 'turn'? Should i therefore assume that 'waypoints' = 'turns' ? Is there a way of seeing the time/distance to a particular waypoint/course point that i manually add? Typically i'm keen to know, pretty early on in a hike, how far/long it is until a) lunch b) the top! I couldn't find a way of doing it though.
3. Fields i didn't understand: there were quite a few.
i) ETE: what does that denote? The estimate time to reach the end point? it was flicking about almost randomly early on, so i gave up on it.
ii) 'Dest. Waypoint' - what does that do? Is that meant to be co-ordinates of the destination? it was blank on mine
iii) 'Waypt. Next' - this was blank for the whole hike until my 'summit' waypoint was next, at which point it showed that waypoint name. So they're all unnamed apart from the ones i add manually (and name) ?
iv) 'Course' - this cryptically said '090' throughout. What's that? The name of the course? Wasn't what i'd named it.
v) VMG - this is the speed to the final destination?
vi) 'Vertical Speed to Tgt' - is this to a waypoint? or the highest point on the elevation profile?
vii) The navigation pages - two of them i think. Are these customizable? I found they added some of the fields i added manually, so a whole bunch doubled up.
viii) Red blob: what is that red blob bobbing around the inside of the bezel...is this the direction to the next 'turn' ?
4. On the maps screen: there are often three arrows: red, blue and white. What do each denote? It appears to be North (i.e. a compass) and current location for red and blue, but i have no idea what the white one is.
So overall, it worked out well, but a few things along the way had me pretty befuddled.
Post hike, a few more things spring to mind.
5. Locations not synching: i added a few 'locations' in Garmin Explore, and named them. I have synched my watch since, but they don't seem to show up on it. What am i doing wrong?
6. Garmin Explore generally: I am still looking for a full explanation of what Garmin Explore actually does. From what i can see, it adds Tracks and Routes (which seem indestinguishable from Courses to me) but cant actually create any, despite seeming to have the best looking maps. The pdf manual spends more time talking about messaging and linking to social media.
One other unrelated niggle, this time when running. The 'total time' field on my old 735xt kept the seconds showing when it got past 1hr of activity (e.g. 1:01:35) whereas on the Fenix 5 it seems to knock the seconds off and show 1:02.. which is a little annoying. Any way around that?
Crikey that was longer than i thought... partial answers/thoughts/comments are most welcome.
John
