Display firmware or software file
Is there a file for reflashing the main display of this watch? I have noticed that one of the black lines which divide menu items from each other has become noticeably corrupt when my watch was upgraded to v6.00 firmware through Garmin Express. Not a major problem but more of a niggle. I have reflashed the individual items like BLE, Sensor Hub and even reverted to V5 but no difference.
Cheers,
Andy
    If by "corrupted" you mean instead of a thin black line you now have a thick grey bar between the "Clock" and "History" options, then that's totally normal.
    So your saying a random differently formatted divider is there by design? Find that hard to believe and there for no apparent reason.
    Cheers for the answer
    I’m noticing the same thing. Only in that menu. So this is normal? Others with a 5x plus can replicate this?
  • I’m noticing the same thing. Only in that menu. So this is normal? Others with a 5x plus can replicate this?
    Yes, as mbirth has said, it's been discussed before too.
  • Had 3 5xPlus's and all of them showed that thick gray line!
    hi all,
    yes was discussed and yes this is normal.
    and make sense to me.
    History and Settings, the bottom two, are the general ones.
    And are separated from the specific menu by this gray tick line.
    You enter the settings (keeping the "up/menu" pressed) from different points (watch face, activity, etc)
    At the beginning you have the specific settings options for the mode you enter the settings, divided by a thin line "|" ...when these end, a "||" is separating from the History and Settings
    e.g.
    - | Watch Face| Clock || History| Settings ....if you enter from home watch face...
    - | XXXactivity settings| Training| Navigation| Remove| Copy | etc || History | Settings ....if you enter from XXX activity...
    thank you,
    robert
