Software Version 6.00 Now Available!
Software version 6.00 is now available to 100% of users.
This software version is being rolled out in phases and can be downloaded through Garmin Connect Mobile or Garmin Express when available.
Changes made from version 5.10 to 6.00:
  • Added support for SwimRun auto sport change. (Swimrun > Menu > Settings > Swimrun Auto sport Change)
  • Added UTC offsets to the Alternate Time Zones list.
  • Improved ClimbPro to support route recalculations when exercising the “Use Map” routing setting.
  • Improved the waypoint navigation experience when using MOB.
  • Made several improvements to the music experience.
  • Fixed an issue where the “Time Ahead” and “Time Bhd” data fields won’t populate while racing an activity.
  • Fixed an issue where non-GPS activities were being displayed in the Navigation menu.
  • Fixed an issue with backlight level when using Flashlight.
  • Fixed an issue where the sunrise and sunset times in New Zealand were not taking daylight savings into account.
  • Fixed an issue where the heart rate zones could change from %LTHR to %HRMax after a software update.
  • Fixed an issue where the device would connect to Varia Lights when cycling through certain widgets.
  • Fixed an intermittent issue where the device was calibrating altimeter during indoor activities.
  • Fixed an issue where the device could crash when accessing History through the Last Sport widget.
  • Fixed an issue where certain CIQ watchfaces were displaying the incorrect date.
  • Fixed an issue where certain sets edited during a rep counting workout were not getting saved as expected.
  • Fixed an issue where GPX routes imported from BaseCamp had invalid elevation data.
  • Fixed an intermittent issue where the device could switch to high power mode, and search for GPS and other ANT/BT sensors while playing music outside of an activity.
