Bose Soundsport Free left earbud is disconnected with using with my F5X+
Im having now an issue with my pair of Soundsport Free headphones. At the beginning they worked OK, I experience occasional dropouts but they connected with no problem.
A week ago, this is when it started failing on me. As soon as I took them out of the case and connected them to the Garmin watch the left earbud did not work at all. I put them back in the case, took them out again and connected, this time both earbuds were connected.
Two days after, it became constant where taking them out the case and connecting them to the watch, leaves the left earbud disconnected. I also noticed that when this has happened, I connected them to the phone where both sides connected properly. Reconnected them again to the watch and they both were connected.
Its as if the connection to the phone resets them or something. I cleared the list of paired devices several times but with no different result.
Has anyone who is using the Bose Soundsport Free experienced that?
  • I own the same ones. I had that happen once maybe twice. I did the same thing that you did the first time. I learned that the left one actually did not charge for some reason as I guess it was not in the case right. Once they charged, it worked. You may try hitting the button on each too. The last time I put them in I had to wake them or something- I hit a button on each and then it connected and worked.
