But no difference with a black bg vs a white one.
No in transflective display .. same battery consuption
With this display technology, white vs black backgrounds don't make any difference. I believe it's called something like "memory in pixel', where power is only really used when a pixel changes.
Seems logic. Thanks!
Interestingly Garmin doesn't even mention "selecting a black background" in their post Maximizing Battery Life, so Forerunner is probably correct in stating that the difference is negligible. I did a bit of testing on my tablet where there should theoretically be a significant difference, and I couldn't see any. But I would be curious to hear if anybody has run actual tests on a Garmin watch.
So in my case it’s 3 times as much: I recently discovered benefits of white background making numbers much more notable to my eyes while sitting at home office in cloudy Germany ...
i switched a face called Shariot J-Shock and tested my hourly consumption in a “silent mode” (no notifications, gps, etc.).
while the face is quite populated, it appealed to me due to extremely fast and low power cons. parameters. But! The moment I switched it to white mode, it started eating 0.3-0.4% per hour instead of 0.1 previously.
so yes, I see a big difference of a factor of 3 between white and black background.
According to Garmin, *no*
"when the display is static, it uses zero power."
https://www.garmin.com.sg/minisite/garmin-technology/wearable-science/chroma-display/
