[Bug Report] Fenix 5 Plus - Sets Edited During Workout Do Not Save
SW Version:
4.20 (0dd4327)
During a strength workout, when you finish a set the watch provides an opportunity to edit that set to confirm or change the reps or weight for the set. However, sometimes it does not save the edit and you have to edit a second time. The issue is intermittent.
Expected result:
After editing the set, the updated values are saved and displayed on the edit set screen.
Actual result:
After editing the set, the old set numbers are shown and the edit is discarded. Editing the set a second time always seems to work.
Steps to reproduce:
  • Create a workout with a Warmup step (Lap Button) and a Repeat step containing a Workout and a Rest step (Timed).
  • On the Fenix 5+, select Strength activity, then select the workout and start.
  • After the Warmup step, perform the first set of the Repeat.
  • Press the Lap Button to finish the set. A screen allowing to edit the set appears.
  • Edit the set (change the reps and the weight).
  • Confirm the edit, then observe that the edited values were not saved.
  • Edit the set again and the values do save.
