Fenix 5 Plus - Fix for Czech language translation file
ORIGINAL GARMIN TRANSLATION CZECH LANGUAGE FILE <czech.ln3> contains some major and minor errors which we consider unacceptably wrong and misleading or unclear at least, so HERE IS a FIX/TUNE. I hope this publishing of fix/tune can lead to more corrections and maybe Garmin itself can consider to fix its factory language files.
WHAT YOU CAN EXPECT: Fixed/changed language file can lead to better device user experience and publishing it here can lead to some suggestions to make another fixies/changes which potentially can help Czech users. All you do is at your own risk (as described in disclaimer below). If you accept that, you are allowed to use info, files and steps provided here at your own risk and you are welcomed to suggest any changes and report another strings to be fixed or improved.
DISCLAIMER: Validity of information from me here is based on software versions and just user observations and there is no guarantee it will be usable in future and also there is no guarantee that it will not cause any damage to devices (or to people as a result of some malfunction of a device influenced by the info, files and steps provided here.) You use any information and files from here at your own risk in full scope with all possible consequences. If any damage happens, you can blame just yourself only. Also if you or anyone else will experience any problems or direct or indirect damages because of info or files or steps provided here by me, it will be result of your risk you deliberately run and you are the only responsible person for that.
EXAMPLES OF FIXED ERRORS AND CORRECTIONS/TUNES: Pls see next post.
INTRO HOW LANGUAGE SETTINGS WORKS (incomplete info):
Nearly all language specific text strings are loaded from language specific files XXXX.LN3 from directory GARMIN\Texts\.
So when you connect your fenix 5 Plus to your PC, the Czech file is here:
\\This PC\fenix 5 Plus\Primary\GARMIN\Text\czech.ln3
When language is changed (from Settings\System\Language\<specific language list>), the system just loads all rows from this file and according to the numbers in the beginning of each row it use them for appropriate places in the device. This means if there is some row missing, the English text will be used instead (which especially is the case when the firmware has menu items which are not present in the language file).
HOW TO INSTALL FIXED/TUNED VERSION OF TRANSLATION:
  • Connect your fenix to PC and backup your language file \This PC\fenix 5 Plus\Primary\GARMIN\Text\czech.ln3
  • download the ZIP file: GarminFenix5Plus-czech.ln3.verX.XX-tuneXXX
  • unzip the file with folder structure somewhere or you can use the file directly from the ZIP archive, if your system or program allow that.
  • copy-replace the file \This PC\fenix 5 Plus\Primary\GARMIN\Text\czech.ln3 by the file from ZIP: ...\TUNED\czech.ln3
  • disconnect your fenix from PC
  • you do not need to reboot fenix, just change language to English and back to Czech (this loads the translation from the file)
  • enjoy fixed/tuned translation
  • if you do not like it, just replace the file by your backup you have made in the step (1).
DOWNLOADS:
NOTE - although there is firmware 3.53 available, the latest available version of language file <czech.ln3> is still v2.20 only (now 2018-07-30), so some menu items are missing in the file and they cannot be easily added by me, because I do not know the menu number and although it is possible to engineer that, I do not have enough time for such investigation, so will wait for official newer file.
Filename convention:
verX.XX = version of <czech.ln3> file,
tuneXXX = version of fix/tune.
<GarminFenix5Plus-czech.ln3.ver2.20-tune101.zip> https://drive.google.com/open?id=1z2...eEpqO6RPNGkErj
    [TABLE="border: 2, cellpadding: 0, cellspacing: 0"]
    [TR]
    [TD="width: 92"]CATEGORY[/TD]
    [TD="width: 236"]DESCRIPTION[/TD]
    [/TR]
    [TR]
    [TD]1-error[/TD]
    [TD]Critical translation error with complete change of meaning - user cannot understand.[/TD]
    [/TR]
    [TR]
    [TD]2-inconsistent[/TD]
    [TD]Inconsistent translation - meaning is similar, but misleading because the term should stay consistently same in all occurrencies.[/TD]
    [/TR]
    [TR]
    [TD]3-untranslated[/TD]
    [TD]English text in Czech file instead of czech text (english form is not similar to czech) - problem for a user who do not undestand english.[/TD]
    [/TR]
    [TR]
    [TD]4-preferential[/TD]
    [TD]Improved translation in regard to meaning and understandability and using shortening of words, which we prefere this way.[/TD]
    [/TR]
    [TR]
    [TD]5-cosmetic[/TD]
    [TD]Cosmetic change or minor translation/untranslation error with negligible change of meaning - user can fully understand if not fixed.[/TD]
    [/TR]
    [/TABLE]
    NOTE for national characters displayed here in the forum: Because this forum corrupts accented characters, some of them are replaced by equivalents without the accent in the table below.
    Of course the ZIP file with the tuning in the first post has all characters correct in the files as well as the attached picture.
    NOTE for non Czech speaking people (hope localization project managers)/: In the example below the original English words refers to the items in the watch face.
    DIAL (05493): meaning of wrong factory translation is "Initiate a phone call = Vytocit" and it should be "watch background= Ciferník"
    HANDS (03633): meaning of wrong factory translation is "Movement/Shift = Posun" and it should be "hands = Rucicky"
    SOME EXAMPLES FROM <...tune101.zip> XLS file <GarminFenix5Plus-czech.ln3.ver2.20.XLS> [TABLE="border: 2, cellpadding: 0, cellspacing: 0"]
    [TR]
    [TD="width: 236"]\FACTORY[/TD]
    [TD="width: 236"]\FIX-TUNED[/TD]
    [/TR]
    [TR]
    [TD]1-error[/TD]
    [TD="width: 236"]05493 Vytocit[/TD]
    [TD="width: 236"]05493 Ciferník[/TD]
    [/TR]
    [TR]
    [TD]1-error[/TD]
    [TD="width: 236"]03633 Posun[/TD]
    [TD="width: 236"]03633 Rucicky[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]05905 Pridat pomucku[/TD]
    [TD="width: 236"]05905 Pridat doplnek[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]01579 Cinnosti a aplikace[/TD]
    [TD="width: 236"]01579 Aktivity a aplikace[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]00270 Zadat akt nad výšku?[/TD]
    [TD="width: 236"]00270 Zadat aktuální nadmor. výšku?[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]06521 Vých. sl.[/TD]
    [TD="width: 236"]06521 Vých.Slun[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]06522 ZáSlun[/TD]
    [TD="width: 236"]06522 Záp.Slun[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]06362 Cykl. na nezp. cestách[/TD]
    [TD="width: 236"]06362 Cykl. nezpevnené cesty[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]06361 Jízda po smíš. povrchu[/TD]
    [TD="width: 236"]06361 Cykl. smíšené povrchy[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]03616 GPS je silnejší venku, v dost. vz. od stromu a vys. budov.[/TD]
    [TD="width: 236"]03616 GPS signál je silnejší venku, dále od stromu a vysokých budov.[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]05502 Zamykací/odemykací tlacítka[/TD]
    [TD="width: 236"]05502 Uzamykání tlacítek[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]06647 Pos/Prib a oddálit[/TD]
    [TD="width: 236"]06647 Posun/Merítko[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]02013 Plav. v baz.[/TD]
    [TD="width: 236"]02013 Plav. bazén[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]06033 Vyst. patra[/TD]
    [TD="width: 236"]06033 Výstup pater[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]02353 Ne behem aktivity[/TD]
    [TD="width: 236"]02353 Mimo aktivity[/TD]
    [/TR]
    [TR]
    [TD="width: 236"]01479 Zduraznit barvu[/TD]
    [TD="width: 236"]01479 Odlišující barva[/TD]
    [/TR]
    [/TABLE]
    ---ciq.forums.garmin.com/.../1392597.gif
