Connection problems
Hi,
I have some problems with the 5x+. I can connect to wifi, Bluetooth, ANT and everything works fine. Then, suddenly, the watch isn't able to connect to anything. It looks like that something blocks every connection. After a reboot, everything is ok again...
Has anybody the same problems, too?
Stefan.
    I have the same problem,
    no connection and den bluetooth_ant update (v2.80) doessnt work.
    do you fix it ?
  • No, I didn't. Bluetooth is on 2.8. Bluetooth is mostly working, Wifi only sometimes (My router says that the Fenix is connected!) It looks like that the watch has problems when you use Wifi AND Bluetooth at the same time...
    ANT is working at the moment.
  • I am having the same issues.  5x plus always has trouble finding wifi.  I am using iPhone X as one of my wifi connections and the other is a home wifi.  I may try the above and reinstall.
