Disappointing battery life
I have just upgraded from a Fenix 5 to a Fenix 5 plus and so far I am finding the battery life to be a lot less than I would expect.
I used to get nearly 2 weeks battery life out of the Fenix 5 but so far the Fenix 5 plus has used 25% in 2 days, both watches are set up and used exactly the same.
I know the Fenix 5 plus is supposed to have slightly less battery life but at this rate it is not even going to last a week.
Does anyone know if this will improve if I cycle the battery a couple of times or if this is normal for this model
  • As I've seen it on occasions and seen someone else mention it. How many of you have seen the battery level stick at 100% after a charge (normally cured by a reboot)
    Also noticing worse battery life after 4.2 update (battery life was already pretty poor prior to this).
    Yesterday the battery was at 84% and I went for a 1 hour walk (recorded with GPS) --> down to 75%, not terrible. I then go on a 35 min walk and it is down to around 55%.
    2 hours later I am going to bed and look at my watch and battery has drained down to 35%! After charging it up a bit, the battery continued to drain about 0.5% per hour.
  • Also noticing worse battery life after 4.2 update (battery life was already pretty poor prior to this).
    Same here!
  • I updated my Forunner 935XT with Software 9,3 version, now the battery is working just for a couple of hours (No GPSs activated, no activities just watch). I already reboot/reset the device, any suggestion? thanks !
  • Massive battery drain on beta 4.59.... :-(
    Charged F5S+ to 100%
    Charged FR645 to 100%
    Ran 12k in 1 hour.
    F5S+ down to 84%
    FR645 down to 93%
    30 min later
    F5S+ down to 80%
    FR645 still on 93%
    Extremly dissapointing...!O(/&!)/%!!
  • My 5s+ doesn't make it 48 hours in my normal use (no music, notifications, about 120 minutes of GPS tracking per day across two activities). I have to charge it every night.
  • Massive battery drain also with 4.61b!
    Same here. Having charged it to 100% and after installing 4.16b yesterday it is down to 67% after only 18 hours. Only "activity" had been 10mins of walking with GPS to test the GPS-update. In 4.20 it was defintely much better
  • It seems that gps chip remains active even if activity is stopped...
    Is there a simple and secure way to shut the GPS off - beside resetting the watch?
    Btw. first impression is that GPS performance improved. Just compared it under not-too-difficult conditions during a 10k run with the smartphone tracker and the tracks now look pretty much the same.
