Battery life ofr music (no GPS+music)
Hi,
The info available tells you about 4 hours (F5s plus) with music + GPS, ok, if im not using GPS but only music how much hours can i expect??
Best regards,
    That's a good point. I'd like to see some official numbers on that.
    That said, obviously it must be less than GPS mode, since it more than halves it. My expectation for 5S would be something little over 7 hours:
    Drain on battery in watch only mode is about .5%/hour, drain on battery in GPS mode is about 9%/hour, and drain on battery in GPS+music mode is about 22%/hour. Which leads me to believe music only will eat about 13.5%/hour.
    Yep, maybe it's no so linear but could be an aprox. (knowing battery life for only GPS and GPS+music i mean).
    Another one: battery life managing maps stuff?? one thing is using GPS but maps used to be batt. consuming beasts...
    Maybe we could search for capacity in mAh for each model??
