Can't connect to paired ant+ sensors
Hi all,
I've paired the Enduro with a number of sensors, including power (wahoo kickr), heart rate (h10 and tickr fit), as well as a rd pod. However, the watch wouldn't connect to any of them this morning. A restart fixed the issue, but I'm a bit disappointed since the watch is nearly stock, with almost no CIQ apps installed. Is this a common issue? I'm running FW 23.10.
  • I am sorry there was an issue. No. The issue you had is not common with any of our outdoor watches. If you experience any odd behavior, a normal restart will often resolve the issue like it did for your watch. Also, sometimes a hard reset needs to be done by holding down your top left button until your watch shuts off then let go of the button.
