I've been having trouble with My Garmin Enduro sometimes not synching activities and I have narrowed it down to my use of the "Resume later" feature.
I often go on long rides, and use the Resume later feature when I'm stopped for coffee / lunch etc. When I synch it later, it does not appear in my Garmin activities list and is greyed out on my watch in the previous activities list. If i try to import manually into Garmin Connect i get the error "One of your files was not accepted by the system. Please contact Support for assistance." If I use an external fit repair website it works and i can successfully import into connect.
Using the website http://www.rainorshine.bike i've been able to load in the FIT and view it and sure enough, at the time when I used "Resume later" i find
latitude, longitude, heartRate, distance, grade, temperature, timestamp,
-27.46849120594561, 153.08883662335575, 105, 51.20226906539, NaN, 84.2, 21345,
-27.468480141833425, 153.08882765471935, 104, 51.20319490818, NaN, 84.2, 21348,
-27.468470418825746, 153.0888219550252, 106, 51.20391569854, NaN, 84.2, 21356,
179.99999991618097, 179.99999991618097, 109, 51.20391569854, NaN, 84.2, 21385,
179.99999991618097, 179.99999991618097, 112, 51.20391569854, NaN, 84.2, 21388,
-27.468709386885166, 153.08950667269528, 88, 51.20454949696, NaN, 89.6, 25831,
-27.468699663877487, 153.08950927108526, 88, 51.20522679135001, NaN, 89.6, 25832,
-27.46867150068283, 153.08951346203685, 87, 51.20684235595, NaN, 89.6, 25836,
-27.46864853426814, 153.08948596939445, 90, 51.209184924620004, NaN, 89.6, 25841,
(see the 2 rows with lat long both 179.999) - you can also see that the time stamp jumps around this time.
also when I view the FIT in this website I get
which kind of confirms that something is going wrong with lat /long
I've noticed this happens a few times during my activity - which might just be the default when I am out of GPS range because under cover etc. But, is this causing connect to fail to import the activity? is it the 180,180 lat/long or is it the jump in time stamp that is causing the synch error.
I'm attaching the .FIT file in case any smart person can help debug why I'm getting these errors. https://www.dropbox.com/s/2oqnlasqdkfmmf5/2022-02-06-07-27-01.fit?dl=0
Steve
