Hi Garmin,
This is beyond frustration. While your customer services seems useless and your product keeps crashing like this, I'm more willing to switch to Coros Vertix 2 right now. I hope either you fix this file for me or I'm literally done.
Hi Garmin,
This will work for you - 2021-12-09-17-05-36-fixed.fit
How did you do that?
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import…
Yeah I have missed that part. And thanks! That was a fun race!
You are a life saver! How did you do that? I tried to find so many solution that none worked out. Could you please help me fix another file in my other thread? I will really appreciate that! It was an 50 miles ultrarun that Garmin crashed on me which is pretty bad. Thank you so much!
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this works. Then change the activity type from "Other" to "Running."
I checked your second file and it is also repairable using FIT File Tools.
It works! Thank you so much!
3945960, congrats on the run! One of Jamil Coury's races.
The fix was mentioned by in your other thread. Maybe you missed it?
- at the moment turn off self evaluation in the activity settings as a workaround
you can repair the fit file by running it through Fit File Tools's section remover without any actual removing
try it
Sorry my bad. The frustration is towards Garmin not you! Thank you so much for the solution though. I was focusing on how to turn off self evaluation.
