I have noticed that I get multiple sync failures after doing log dives (90 minutes and greater).  It appears the FIT file gets to a size where a timeout between the Descent and Garmin Connect Mobile becomes more likely.  This happens even when the Descent is less than a metre from my iPhone.
I'm sorry the image is so small.  These fora make it impossible to upload a image and keep its size.  You can at least see how many times sync has failed.
Here are the errors from the sync report which are common across all the failed syncs for long dives.  Eventually, it will sync but it can take an hour of trying.
[FONT=courier new]UPLOADS
   File Type           Filename                                        Size (bytes)   Status
   FIT_TYPE_4          1-3966683484ble-FIT_TYPE_4-2859-31-893653287    245543         Error
   FIT_TYPE_35         (null)79             Cancelled
   FIT_TYPE_32         (null)2901           Cancelled
   FIT_TYPE_32         (null)484            Cancelled
   FIT_TYPE_32         (null)431            Cancelled
   FIT_TYPE_32         (null)624            Cancelled
   FIT_TYPE_32         (null)569            Cancelled
   FIT_TYPE_32         (null)554            Cancelled
   FIT_TYPE_32         (null)902            Cancelled
   FIT_TYPE_32         (null)749            Cancelled
   FIT_TYPE_44         (null)335            Cancelled
   FIT_TYPE_41         (null)14789          Cancelled
DOWNLOAD DEVICE FILE TYPES
   File Type
DOWNLOADS
   File Type           Download ID         Size (bytes)
ERROR DETAILS
Error Domain=GCMSyncErrorDomain Code=2 "Device connection error" UserInfo={SyncErrorReason=File UL: Failed to receive file from device, NSLocalizedDescription=Device connection error, NSUnderlyingError=0x1c4a5f3e0 {Error Domain=GarminDeviceSync.FileTransferErrorDomain Code=16 "(null)" UserInfo={GarminDeviceMessageError.ErrorReasonKey=Timed out waiting for file data request.}}}[/FONT]
