Descent MK1 Dive Feature Suggestions/Changes
Ok, we all know that this watch is loosely based on the 5x so any features that pertain to any other sport function can be posted in the 5x forum. I’ve had this watch since the beginning of January and I’ve had enough time to formulate opinions and/or suggestions. I’ll post mine and for those of you that would like to post yours here, you’re more than welcome to:
1. Posted and submitted this as an issue but will reiterate it, the Diving Compass only looks at True North, not Magnetic North like most compasses. Allow the user to choose MG or TN for their Diving Compass or have it default based on your normal Compass widget setting.
2. Have an option to turn off “Auto Dive” on the watch. As an Instructor, I’m always up and down with students in the pool. I have all the necessary skills timed out and look at my analog clock as a reference. I do not need the watch to go into dive mode when I’m in the pool. It’s quite annoying. So there should be an optional n to “turn off” that feature.
3. The normal “Barometer” widget is effected after a dive (picture below). Maybe disable the widget from trying to read while in the water.
ciq.forums.garmin.com/.../1319115.jpg
    I would like to have the option of changing the final stop depth for decompression dives. The Descent is fixed at 3m but I use the Descent as a backup computer and use a Shearwater Petrel2 as my primary computer. The Shearwater allows you to change the final stop depth from 3m to 6m. This is important if you often dive off a boat in conditions with some swell. It is more difficult to maintain a deco stop at 3m than at 6m in these conditions even if the overall deco is slightly longer.
