CT10 and SuperStroke Putter Adapter
I've been looking for a solution to mount a C10 adapter to my SuperStroke putter grip. After countless hours of research, most of the DIY solutions are a bit of work and they still don't look great. I've been using one for about half a year and it fell off, which led me to make another one.
Fortunately, I was playing a round this fall with a member who had a CT10 attached to his putter flawlessly. I asked where he got it and there's a company called Only Bogeys [link removed] that makes this adapter.
I've been using it for the last few weeks and it is the perfect solution. You simply unscrew the SuperStroke cap, screw in their adapter, and screw in the SuperStroke into it. It holds it supertight and sits flush with the putter.
A bit pricy but well worth it as you'll spend quite a bit of time making one for something that doesn't work as well and doesn't look as nice.
Just thought I would share this setup as I'm sure many are in the same boat.
External link removed per Terms of Use
