Sleep data is delayed for a day. And the sunrise and sunset times do not change: 10:45 sunrise and 11:09 sunset. Was there a recent change in the software? Seems like I am in a different time zone!
Check settings directly on the watch to makes sure that the time section shows "Set Time" set to Auto. Open Start Round menu > Scroll & select Settings > Select Time > Set Time = Auto > Take watch outdoors with sky directly above you, and select the Start Round option in the main menu to locate satellites > Once nearby courses are displayed on the screen, tap the BACK button on the lower left side of the watch > Time/Date/Sunrise - Sunset times will then display accurately.
Your sleep is likely transferring later due to the watch not syncing with the Garmin Connect app...or due to the time setting. Also make sure the sleep/wake settings in the Garmin Connect mobile app are accurate for the time you are planning on sleeping.
