For a while, now, I get the message on my s20 that an update is available but every time I try to install this, my s20 shows an "update failed" notification. I also notice that my s20 doesn't seem to be able to find satellites. What do I do now?
Try connecting your watch to a home computer with Garmin Express installed. If the Approach S20 is added as a device, check and see if updates are available to install when connected to see if that resolves the issue with the update failed alert you are seeing.
If you are unable to resolve the install prompt appearing using Garmin Express, more in-depth solutions may be needed with the guidance of Garmin Support.
For further solutions, contact Garmin Support for your region.
Thanks for the suggestions. All updates are completed from the application Garmin Express side. The error occurs when I try to apply update on the watch after disconnecting.
