I've updated my montana 700 to 15.10 version, and after update, when I scroll data field pages Montana auto shut down!
How can I solve this problem?
Ok I try to describe the problem. On maps screen Montana works fine and I move map left to right without problems, also compass screen works fine. The problem is on data fields because I've two data pages and when I try to scroll from first page to second page , montana auto shut down.
Good News: I am unable to duplicate with my Montana 700 v15.10.
Bad News: You likely need to perform a Master Reset of your Montana 7x0.
Make a copy of the Profile folder on your Montana 7x0, then after the Master Reset, copy one profile back and test for crash again. If OK, copy additional profiles back to device and test more.
If the Crash Returns, you will need to Master Reset again and recreate your Data Field configurations manually.
Ok I've restored to factory defaults my montana and now the pages of data fields works fine!
I've a question about data fields pages: in the menu button at the bottom right, exist a field with " Connect IQ data field" but nothing happens on the screen..
What is its function?
