I can’t save contacts in my 750i under the In reach
I can add the name and numbers but the save button won’t work???
  • Hi
    I had a simular issue with my Ireach contacts on my 700i.
    Contacted Garmin support and they suggested to do a full reset.
    that solved my problem.
    I hope this will help you.
    Performing a Full Reset
    1. Power off the Montana
    2. Press and hold Power until the LED becomes red, then release
    3. Double-tap Power to start the reset
      • The screen will indicate it is resetting and display the progress, then shut off
    4. Power the Montana back on normally
    5. Select your language
      • The Montana 700i and 750i will display the option to Activate or Skip, select Skip. You will then need to re-pair and sync with the Explore app
  • Do not skip activation. You DO need to repeat the outdoor portion of the activation after a full reset.
