Dear developers/forum members,
I created some custom groups of maps.
I find this feature very effective and one of the most interesting improvements over the montana series.
The fact is that since these group has been created the unit became instable.
The unit shuts down:
-after the initial map loading has been completed
-when the map groups icon located in the map screen is tapped
-when a group of map is selected from the side bar invoked by the map groups button
if the previous actions didn't cause a shut down in the immediate, this will happen randomly after a while.
This happens only with custom groups of maps created by the user.
When custom groups of maps has been removed the unit operates correctly.
The memory that hosts the mapsets (intermal or SD Card) is not involved: I tested with maps installed into the internal memory and SD Card and the behaviour is the very same
Tested with different groups of maps and with a group containing a single mapset (every single mapset tested)
Thank your very much indeed for you support.
Best regards.
Andrew.
Montana 750i, FW 10.90,
Internal Memory: CN Europe NT 2020.10 - Id. 8041 TopoActive Europe 2020.10 North East - Id. 8547
SD Card 64 Gb: TrekMap Italia v2 - Id. 2212 T4A Maps - Traveller's Africa 16.10.01 - Id. 8020 Topo Deutschland (Nord) - Id. 535 Topo Deutschland (Sud) - Id. 534 Topo Oesterreich - Id. 706 Topo Custom created maps in the .img format - Id. 9901 to 9970
