This isn't really a quetion but more of an observation.
I have recently tried several different micro-USB cables to charge my 750i: Anker Powerline Micro USB cable, various micro-USB cables from various devices I've had over the years, and the Garmin cable that came with my 750i.
Apparently the Garmin cable is specified as a "2 amp" charging cable, which I've never seen specified in my other cables. In fact, the Garmin website specifically sells a micro usb cable only for the 700 series, whilst they have other micro usb cables for other devices.
The power supply is a high power SiC USB charger, with more than enough capacity to charge anything.
Most of the cables I have tried except for the Garmin USB cable will charge the unit (I know this because the charging icon and battery percentage appears on the screen) for approximately one to two minutes before the device simply shuts off. One other non-Garmin cable I tried charged for about 5 minutes / 8-10% before the unit shuts down.
When I use the Garmin 2 amp charging cable, the unit charges without any shutdowns.
I think the conclusion here is that while most people seem to be focused on the capacities of their charger, they should instead be much more focused on the capacity of their USB cable.
(I have a strong feeling that the Montana draws more than 500mA when charging via USB. I have measured the current draw when charging via the AMPs power cradle and it is closer to 700mA. I don't have a USB powermeter handy, but I think it would be useful if someone who has one could measure the current draw of the Montana when USB charging.)
