Rugged mount power supply
Ive just installed my 700i with a rugged mount, and I initially was powering it from my Neutrino Elements Plus power distribution module, which is activated by the ignition. The 700 starts fine, then goes dull after a minute or so and when I key off, there is no prompt to say external power has been lost. This leads me to believe that as the screen goes dull, it has switched to battery power. Is this correct ?
Ive since hooked it directly to the battery, and it works fine now, dosnt go dull, however as it is connected to the battery, its permanently on and I have to turn it off manually or take it out of the cradle.
My neutrino is supplying battery voltage fused at 3 amps, so Im curious as to why it wont work supplied from the module ? Am I missing something fundamantal here ? Has anyone had similar experiences ?
