inReach Mini Battery Replacement
I have had my inReach for 3 years and have only used it a couple of times. I have come to the conclusion that my device is defected. It won't charge and I can only get it to show the "connect USB" screen and the "Sun and Battery" screen. The device is never hot and I have left it charging for many hours, even over night. I have read there was a firmware issue if the battery got too low it wouldn't charge so it needs to be updated. I have tried updating with no luck and hard reset and updated and still no luck. I spoke to Garmin support and they told me I need to pay $130 for a replacement which I find ridiculous. It is not my problem they had a firmware issue. A device that is expensive should not only work twice regardless of how long you have had it.... So my question is, if I replace the battery will this fix my issue? I have found this battery: https://www.ecrater.com/p/38852824/battery-garmin-361-00114-00-for-010-01879-inreach-mini?gps=1
I do understand the mAh are lower, but figured its better than nothing. If anyone has any insight, it would be greatly appreciated. Thank you!
