Transmit power table of different iR devices
I found this interesting table at a short first impressions report about the M3+ on the hikingguy homepage:
hikingguy.com/.../
Device Transmit Power (Watts)
inReach Mini 1.48 W
inReach Mini 2 1.51 W
inReach Mini 3 2.63 W
inReach Mini 3 Plus 4.68 W
inReach Messenger Plus 9.33 W
GPSMAP H1 Plus 1.99 W
So no doubts regarding this table, the Messenger + has the best transmitting power, but M3+ seems even to be better as H1+.  Based on these values ​​and in reality, the Messenger Plus is way superior to all other iR devices and is the absolute reference (antenna/ transmit power), this are my personal experiences, too. The Messenger Plus is the benchmark, but are the 9.3 watts really accurate? Has anybody found a source for the above mention “transmit power” of Messenger + and M3+ except hikingguy? I haven’t found.
  • Btw: dcr hasn’t released his M3+ review because of this: “I’m waiting for Garmin’s investigation into a satellite failure I had (kinda a big deal). It sounds like they’re close to having clarity on the issue (and some sort of details that I can include in the review, whatever they may be).” I am really curious about which “ satellite failure” he is talking about?! I haven’t noticed any satellite failure so far.
  • With just these numbers there is no way to tell the amplifier power or the reasons Garmin chose to use different output strength in these devices.
    They don't list whether it's EIRP (Effective Isotropic Radiated Power, which adds in antenna gain / efficiency) or just power at the amplifier output.
    I would be pretty surprised if the Messenger Plus really put out 9.3 watts..  On the other hand if this is power at the amplifier output the different in output could be to equalize the transmitted output after antenna losses.  The Messenger antenna may need more power to reach the Iridium receiver.
    A 1.48 watt transmitter with a very good antenna is better than a 9.33 watt transmitter with a poor antenna as the battery life would be much greater for the 1.48 watt device.  When they design these they balance size / battery / output power to get the result they are happiest with.
    As long as any InReach messages are getting out and received by the satellite the power is adequate.
  • I’d like to actually see official Garmin documentation showing those power valves, not just info from a 3rd party site. 9 watts for the messenger plus is wow, a lot. Most vhf portable transceivers are only 6. Nine watts off a little battery is a lot. It’s really hard to believe that little device can last a few days sending messages at 9 watts. My 6 watt vhf marine radio can’t.
  • -translated conversation-
    Me:
    [...] The point I would like to understand is: if I fall into a crevasse, which device offers me the best chance of sending a signal? Are they all the same in the end, or is one better than the others? I found that: Device Transmission power (Watts) inReach Mini 1.48 W inReach Mini 2 1.51 W inReach Mini 3 2.63 W inReach Mini 3 Plus 4.68 W inReach Messenger Plus 9.33 O GPSMAP H1 Plus 1.99 W However, these power distributions may not necessarily reflect the actual signal reaching the satellite.
    Garmin Technical Support:
    From a performance standpoint, the technical department has confirmed that there are no substantial differences in data transmission between the various inReach devices.
    Among the various products, I would recommend the inReach Mini 3 or inReach Messenger Plus if you do not need navigation and map features. Otherwise, the most comprehensive device is the GPSMAP H1 Plus [...]
  • As I mentioned I would like to see official documentation from Garmin on output power levels, and why they are different. If garmin  are saying that there is no performance difference between devices then you would think the power outputs would all be fairly close to each other for equal or better battery performance, unless the different antennas require different power levels to achieve the same results. I even find it hard to believe that Garmin has even done any tests to back up that statement when they obviously never seem to test their software out. Why is the larger H1 only 2 watts and the messenger plus 9 watts? What is the power output of the original messenger?  I don’t think anyone is going to do a crevasse test on them but I’m waiting for hiking guy to hopefully do a dense forest rainy day test on a few Garmin devices together.
  • In the DCRainmaker Mini 3 review he mentioned the Mini 3 and Mini 3 Plus had different antennas.
    I'm not sure if the 2 different antennas means they use slightly different frequencies which require different antennas or if they use a higher gain antenna on one of the units.  A search on Iridium satellite frequencies shows 1616 to 1625 mhz as the range.
    It would also be interesting to see if the antennas are truly omnidirectional or if they exhibit gain in a certain direction.  That could be the reason for different transmit power levels so the reception at the satellite is about the same signal strength for each device in various orientations.
    It wouldn't be hard for the RF engineers to measure the signal strengths from the antennas / transmitters to and from the satellites so I would guess the statement from the technical department is correct,
    It would still be interesting to have DCRainmaker or Hiking Guy take a few of the units to a marginal location as you mention as a "show me" test.
  • If you want to see official documentation, just check the device user manual.  For the Messenger Plus, transmit power is listed as
    “1.6 GHz @ 39.7 dBm maximum”.  39.7dBm = 9.33 W.
  • if this would be transmitted power, then this device could not be sold to public. This would need special precautions as making it not possble to operate near body, particularly head. Max allowed radiated power is 5W
  • That’s not true Skyeye as vhf marine potable radios are usually 6 watts now. You’re not going to put either by your head like a cell phone. Apparently the messenger plus performs better than the other Garmin InReach devices based on the comments on this forum, but since there are different antennas being used I’m not sure 9 watts on the messenger plus means it’s 2,3 or 4x better than another Garmin inreach. Too bad a Garmin engineer can’t comment on this topic of power output vs transmission capability. Which one is best in a rainy dense forest. FYI the 67i has more power output that the H1 plus if you convert its decibels into power output. Why does the newer bigger H1 plus have less?
  • pls do not confuse vhf and uhf 1.6 GHz
    frequencies have different values as far safety is concerned.
    Power values have also no meaning here, those are obviously not radiated power, just tx power.
    radiated power for calculation of SAR values is measured in defined distances from the antenna, in fact using absorbing medium tuned to the particular frequency of interest.
    with 1.6Ghz, precautions must be done that radiation of abt 3W does not enter the body.
    example:
    iridium hand phones, must have reduced radiated power when simply stored in your pocket and need the user to actively extend the antenna so when in use on full power (~5W) the radiation happens above the head while using the phone.
