Hello,
I am considering the purchase of an inReach Mini 2. My initial use case is merely to internally record Tracks in the field and export this geodata (Garmin Explore or via a USB cable) when back from the field and connected to a mobile or fixed broadband network. The exported geodata (typically GPX format) will be used in other mapping program. To date I have been doing Track recording with a SmartPhone, but I am looking for a dedicated GPS receiver for improved accuracy (Activity Recording = High Detail). The Iridium-based communications is a "nice to have" feature for a future use case, which I understand would require a subscription.
From what I have read on THIS support page it appears I can record Tracks internally and export them using the Garmin Explore app (or via a USB cable) without having an active subscription.
I want to double-check my assertion is correct; Track recording integrally in high detail and later exporting works without a subscription and there are no hidden surprises (like very short recording durations - a four hours of internal recording is probably fine).
Thanks!
--Rob
