Zumo XT and inreach mini 2
I know I can pair these 2 devices - but why would I? What's the benefit? Thank you..
  • Typically, the reason to pair an iR device with some other Garmin device is the ability to remote control the iR device. This is easiest to understand with wearables, such as a fenix watch. Same principle applies to a cycling device like ZumoXT. You can leave the iR device in your bag or basket. You can control it (for example, start/stop tracking) and get notifications of incoming messages using the paired device.
    Be aware of two things. The connection is short-range ANT+. The iR device still needs a decent sky view in order to function at all.
  • Not sure I need this functionality. Don't think I'll pair the devices. Thank you. You've made this clear and easy to understand.
