Mini 2 Caught in Some Kind of "Startup Loop"?
So I took my Mini 2 out today for it's first field test in the woods, and it seems to be caught in some kind of restarting loop now?
It will display "Garmin", the warnings about needing a subscription, and then "test before you go".
If I press the OK button, it will briefly bring me to the main menu for a few seconds, then it cycles back to "Garmin" and the startup sequence again.
If I quickly select "send preset", it will send a message SOMETIMES, but when they are received most of them did not have any location attached.
The device also chewed thru 30%+ of it's battery on a 5 hour hike today, and it's still sitting on my desk cycling in the loop.
I've tried the restart sequence of connecting to a computer and holding the back/power buttons for 10 seconds.  The device will turn off, but then it reboots and goes back to the looping behavior when you turn it back on.
Tried to restore the device to factory defaults, but you can't select thru the menus fast enough to get to that option before the device restarts and begins looping again?
I also noted that it seemed to be cycling a connection with my Fenix 7x Sapphire. While hiking the watch had high battery drain and keep spinning the green circle with "complete" message intermittently?
As part of the troubleshooting procedure I've turned off the Bluetooth connection to my phone and unpaired the Mini 2 from my Fenix 7 and attempted to reset the mini again...still no dice.
Any ideas?
Thanks,
arockclimber
