n this test, I used an activity with routing enabled. Two visual inconsistencies are apparent:
Overlapping purple and magenta lines: The purple line is normally displayed when navigating without routing, whereas a magenta line is used when navigating with routing enabled. In this test, both lines are displayed simultaneously and overlap each other.
Incorrect magenta routing line: The magenta line does not follow the road correctly. Instead, two separate magenta lines lead to the first waypoint. From that waypoint onwards, the magenta and purple lines overlap more or less for the remainder of the navigation.
This is the second test mentioned in my other posts and should be considered alongside the previously reported routing and navigation inconsistencies.
