Duplicate collection on GPSMAP H1i Plus – ghost collection remains
I have a strange issue with my GPSMAP H1i Plus and Garmin Explore.
I had a collection called “Parkplätze” (Parking) in Garmin Explore containing 18 waypoints.
At some point, a duplicate/ghost collection appeared on the H1i Plus.
The behavior is:
  • When Explore synchronization is OFF, the H1 shows one empty “Parkplätze” collection (0 waypoints).
  • When Explore synchronization is ON, the H1 shows two collections called “Parkplätze”. Both contain 18 waypoints.
  • Garmin Explore itself shows only one “Parkplätze” collection.
I have since deleted the collection from Garmin Explore, and the ghost collection still remains on the H1.
There was also a separate GPI-based version of the same parking locations. I had the parking locations in two ways: as an Explore collection with waypoints and as a GPI file created with Garmin POI Loader. I have since deleted the GPI file and the waypoints as well.
I don't know whether the GPI file and the duplicate collection are related. It may be completely unrelated.
The important point is that the empty “Parkplätze” collection remains on the H1 even after the Explore collection, its waypoints, and the GPI file have been deleted.
I can access the H1's internal storage via USB/Commander One on a Mac. I would prefer to remove the orphaned collection manually if there is a safe way to do so.
Does anyone know where the H1 stores its Explore collection data, or how this orphaned/ghost collection can be removed without performing a factory reset?
Firmware: 12.08
Any help would be appreciated.
  • Garmin devices store Explore data in the folder GARMIN\EDM in various binary files ending in .bin. But as far as I know the structure of these files hasn't been reverse engineered.
    Maybe the Remove Temporary Data (or how that option is called) from the System menu resolves the issue? If not then I've no clue as to how you can remove the ghost collection without doing a factory reset...
  • Thanks a lot.
    With your help and the help of chatgpt I got rid of the Ghost. GPT analyzed which collection to delete and created me a new collection_list.bin without the faulty collection therein.
  • Yes, collections (and not only those) are kept in /GARMIN/EDM/. Unfortunately, deleting temporary files does not solve the problem — I had hoped so too :) — but one simple technique I have used to _completely_ clean out the dirty data left behind by the code that maintains EDM is, in streamlined form, the following:
    - Check that the state on explore.garmin.com is correct.
    - To be safe, back up EDM and, if you have data there, other important folders such as Activities, Courses and Locations.
    - Delete the contents of the EDM folder.
    - Restart the device.
    - Sync with Explore. This reconstructs the contents of EDM from the cloud.
    One thing to be aware of: the final sync is a sync from scratch, since deleting the contents of EDM also clears the sync state. If you have a lot of data it can take a long time.
