Altimeter with Software Version 11.07
Hello,
When I read this in the changelog for software version 11.07:
“Fixed a possible issue with altimeter data during navigation,”
I was very hopeful that the altimeter would finally work while navigation is active.
So I went out for a short walk to see if the bugs had finally been fixed after so many software updates
Unfortunately, the whole thing ended very disappointingly.The device still doesn't displays the upcoming elevation profile during navigation.
Like before V11.07, the upcoming elevation profile appears for short moments and then disappears again.
To make matters worse, a new error has been added.
Even though I have muted all sounds in the system settings, the device now plays navigation prompts through the built-in speaker when I start navigation.
The only way to turn them off is to toggle the "Mute All" switch from "On" to "Off" and then back to "On."
Unfortunately, this procedure is required after each restart of the device to disable navigation prompts.
On top of that, the device crashed during my short walk after I left the route and it started recalculation.
Overall to me, version 11.07 represents a step backward compared to version 10.13.
So far, only the frequent random spikes seen in software versions before V10.13 have been fixed.
