GPSMAP H1i+ S/W 10.13
there are two problems:
1st: select a photo > menu > view map > the location is wrong: the map shows a location somewhere 9999 km far away in the ocean.
when in spite of that I wish to see the real place, I save a waypoint:
2nd: when saving the waypoint the message "this location way successfully saved as waypoint: ...." with an ok button below. You can't confirm by pressing enter or using touchscreen. You can not quit the screen, except by killing it (holding page button and swiping up). The waypoint will be saved, but you don't find it easily because you can't find waypoints by date (see my other post). This problem seems to happen only when saving a waypoint out of a photo. There are no problems when saving waypoints otherwise
