GPSMAP H1 Route Simplification Error
Hello everyone
I’m reaching out to you for your expertise (and I think I’m in the right place) because I’m running into a major issue that makes the H1 unusable under these conditions. Suspect
I want to load four GPX files onto it for the 2026 Tor des Glaciers race (a total of 450 km around the Aosta Valley)
It’s a self-supported race with no markings, and I actually bought the H1 specifically for this reason.
The problem is that after importing the GPX via Basecamp (or Garmin Connect—the result is the same), the track is significantly altered and obviously unusable.
I’ve attached two screenshots where you can clearly see that a line is drawn in the H1 instead of following the actual route.
Yet in the H1, the route has exactly the same number of waypoints as in the original GPX file.
I’m also attaching the official GPX file for the race (https://torxtrail.com/wp-content/uploads/2025/08/TOR450-Tor-des-Glaciers-T1-V7.0-START-Rif.-Sella-UP2025.gpx)
It’s impossible to set out on a 6-day race with this file without being confident in it.
I’ve tried everything:
Converting it to a route, leaving it as a track, converting it to a different GPX file from Basecamp.
I tried recreating a tiny portion of the route (just 20 points, as shown in the screenshots). Even when retracing it point by point, it ends up in H1 by drawing straight lines through
Settings:
- Topoactiv map
- Small satellite view overlay to save memory while still providing context
- I still have more than three-quarters of the storage space available on the GPS
- The GPX file contains about 5,600 waypoints in BaseCamp, and it also contains 5,600 on the H1 after import
- In BaseCamp, the base map is the one used by the H1
- The route follows the track perfectly in BaseCamp, on Garmin Connect, on my Suunto app, and on VisuGPX (I’ve tried everything  Very Happy )
- As soon as I sync it to my H1, whether with BaseCamp or Garmin Connect, I get complete nonsense. This is especially problematic because at 3,000 meters at night, a route that cuts straight through the mountain is dangerous
Thanks for your help—I’m at my wits’ end... especially at this price  Shocked
Translated with DeepL.com (free version)
