gpx recording format
I wanted to set up GPX recording in addition to Fit. I only found this option and there is only PX format. Is there a way to set up GPX recording like it was in previous models? In previous models it even worked for me and GPX also included the temperature from the Tempe sensor. Now I see the temperature when paired on the GPS but it is not in Fit either.
  • The "PX" is most likely simply a translation error for the language you're using. In English this option shows as "FIT and GPX". And I can confirm activities will be written as FIT files and GPX files when this option is selected.
    As for temperatures from a connected Tempe sensor not being saved in the activity FIT file: I noticed this as well and reported it as a bug to Garmin. I suggest you do the same, the more people report an issue the more likely it gets fixed.
