H1i Plus, V. 7.07
browsing around on the map and pressing find shows a field "searching near" with coordinates. But after some of the below steps, sooner or later, instead of coordinates this field shows "current location". This is unwanted, it is a bug.
1. Browse on the map screen, press find, the search near, shows coordinates (as expected)
2. as no. 1, but do any of the following
- quit and browse further and press find again
- as above plus touch the screen, move the curser, press find
- as step before, and ex out the info field on top of the map, press find
- ......, press find and search for saved waypoints or points of interest, from the search result go back with quit,
- as above, select an item from the search result, go back (press quit 2x) to the page with search nearby field.
After all these steps the search nearby field should show the coordinates of the map position and after a further press of quit you should see the map with the position where you started searches. But often you don't see no coordinates but "current position". When you then press quit the map shows your current position.
I tested all the steps to find a solution to overcome this jumping back to current location. It is probably not necessary to try all the steps to find the bug.
