GPSmap H1 – 100% reproducible system reset
The device resets every single time after following these steps:
  1. ​Add an "Application" field to the screen.
  2. ​Select "Applications," then "Settings," and then the "Routing" (wyznaczanie trasy) setting.
  3. ​Tap the newly created application shortcut.
​The receiver crashes/reboots in 100% of cases. It seems the shortcut points to a non-existent menu, as there is no "Routing" option available in the standard device settings menu.
