course creator bug
when i use course creator  ,there is very  big bug exist in it,  use   recent finds  waypoints  cities  coordinates   can   make  h1 restart
  • You should list which firmware version your unit is on. There was a v6.04 firmware update released today 12/18/2025. If you are currently running the previous v5.09, the newer v6.04 may have corrected the issue. Update your unit (if you have not yet done so) and try the same sequence of events that you used when the unit crashed.
  • I just created a few very short (using recent finds, waypoints and cities) courses with no crashes on my eTrex Touch (the H1's little brother) running v6.04 with no crashes. It does however take quite a long time (even with a very short course) before the elevation data is displayed (when I choose to display it). This is using Garmin's TopoActive 2025.10 maps. Also, the course creation/calculation itself can take quite a long time as well.
    What maps are you using exactly? It could have to do with those particular maps.
  • Perfect example. Hopefully Garmin will see this. You should probably report it to them via email as well.
    [email protected]
