5.09 broke the ability to select maps in Map Manager
Update 5.09 broke the ability to enable or disable maps in the Map Manager. When selecting a map in Map Manager, the display becomes corrupted for a short time, after which a menu filling half the screen is displayed with details on the map file. This applies to both Garmin maps (e.g. TrekMap Italia v6 PRO Abbruzo, which I purchased for free to test) and 3rd party OSM-based maps.
I reported this to Garmin support, but thought it good to share here as well.
  • Yes, there is no longer the possibility to enable or disable maps with Map Manager, but you can do it with ‘Maps Layer’. I just don’t understand whether it’s a bug or an intentional change.
  • Agree, also not sure whether this was intentional or not.
    For official Garmin maps the change seems to work fine. A TrekMap Italia v6 PRO map I have on my H1 shows as a separate layer in Map Layers. But of course this is only one map and therefore not conclusive.
    But for unofficial 3rd party maps it doesn't work (eg OpenFietsMap or Freizeitkarte). They do not show up as separate layers, but as a single CityNavigator layer (this was also the case on the GPSMAP 67 BTW).
  • Update 5.09 broke the display of KMZ maps I purchased.
    I have purchased maps from the producer, the company Compass.
    In the previous version, they displayed correctly on the map tile list in the 'Layers' menu. Now, the tiles are there, but they have no map name, and the maps are always enabled, regardless of whether I select the tile or not. It is impossible to disable the KMZ map layer
  • Thank your for info, so I can calmly wait another two of three months with a decision whether to purchase this product until they will fix it. From my experiences with 66s, it took more than 6 months of firmware changes after the release, until it BEGAN working. So it seems, there's no sense in buying it before march 2026.
    Rgds
  • This seems to be fixed in version 6.04, released on December 18, 2025. The display corruption issue when selecting a map from map manager doesn't occur anymore.
    Additional maps now show up as separate layers in the Map Layers menu (previously they showed as a single City Navigator map type).
    The toggle in Map Manager has not returned, but I don't consider that an issue anymore as long as maps show up correctly in the Map Layers menu.
    I didn't check custom maps though (don't use them).
