OK,
I just got back from a short hike with a bunch of different GNSS devices in my backpack... I'll post the results shortly..:D
*in meantime check altitude readings :)
Kind rerads,
Teo
OK,
Kind rerads,
Teo
Seems that the H1/altitude is about 100m off
What is also intresting is that H1+ in smart mode produce 10 times more Points than 66 or 67, will post over there...
Huge diffrence in number of recorded points between older models and H1, H! produce 10 times more points which is comparable to what I get from GT6 PRO watch....
Yes, totally wrong although I calibrated 10 days ago at the sea level pressure, yesterday I recalibrated it by GPS altitude and it looks quite better now...
To clarify: does that mean you didn't recalibrate the altimeter immediately before starting your test above???
No, I just turned on all devices, reset the trip computer and put everything together in the backpack, same conditions for all devices, no special treatment for H1. I never calibrate the altimeter before hiking, only if I notice that it is not showing the correct numbers, but that happens very rarely on 66 or 67...
I don't know, maybe I need to turn on auto calibration on the H1. I'll see how it performs in the mountains next weekend...
