OK,
I just got back from a short hike with a bunch of different GNSS devices in my backpack... I'll post the results shortly..:D
*in meantime check altitude readings :)
Kind rerads,
Teo
OK,
Kind rerads,
Teo
62
66
67
H1+
GT6 PRO
CalTopo
Ruuvi is there just like that
I see, you had to use alcohol to survive your test... I hope you report also about the Ruuvi sensor and how it worked and which data field(s) you have used for it.
Working just fine without single problem...
Akoholo is there more because the results than for the test itself
I assume the H1 is updated to the latest firmware. The satellite network and recording settings are important!
Of course yes, all of them with the latest firmware...
Seems that the H1/altitude is about 100m off or the other three devices are about 100m off.
Yes, totally wrong although I calibrated 10 days ago at the sea level pressure, yesterday I recalibrated it by GPS altitude and it looks quite better now...
