Garmin GPSMAP H1 - some early issues
Hi everyone,
I’ve noticed a couple of small issues with my new GPSMAP H1 and I’m wondering if others are seeing the same things. Hopefully Garmin can sort these out with a software update:
  • After every restart, the device always defaults to "Hike." Would be much nicer if it just remembered the last used activity.
  • When I switch activities, the backlight timeout doesn’t work correctly. Even though it’s set to 2 minutes, the screen goes dark after just a few seconds. A restart fixes it – but only until I change the activity again.
  • I can’t find any settings for the users height or weight, which makes the "Calories" field pretty useless.
  • The German keyboard layout is set to "ABCDE" instead of "QWERTZ." Would be great if we could change that (especially since the English one is "QWERTY").
  • When setting a waypoint, the "Averaging Waypoint" function seems to be missing.
Is anyone else running into these? Or maybe Garmin is already planning to fix them in an update?
